We’re UAV GNSS, a Septentrio receiver maker, and “my A/B lines drift a few centimetres between passes” is one of the most common setup problems AgOpenGPS builders bring to us. The receiver is usually not the culprit — here is the order we debug it in.
1. Lever arm, not position, is what you steer. The antenna sits somewhere on the cab; the implement (or the section valves) sit metres behind and to the side. AOG translates one into the other using heading plus an offset, so a 2° heading error at a 3 m lever arm is already ~10 cm of lateral error — before any GNSS error enters the picture. Measure the antenna offset (fore/aft, left/right, height) to the centimetre, and re-check it after any mechanical change.
2. Heading source quality. A magnetometer-based heading is bent by motor currents, steel frames and fences — 5-30° swings are normal on an electric vehicle, and through the lever arm they translate straight into line error. Dual-antenna GNSS heading measures the direction of a physical carrier-phase baseline between two antennas, so it is immune to magnetic interference. If you run a single receiver, at least log the heading source during a pass and watch it.
3. Fix state at the moment of recording. If RTK was fixed when you recorded the line but floats during the pass (or wanders at section boundaries), the line is fine and the execution is not. Log fix status and correction age continuously; only trust a line recorded in fixed.
4. Base movement and repeatability. A base nudged a few centimetres shifts the whole field for every later session. Fixed/surveyed base coordinates and a solid tripod matter more than most people expect.
5. Section timing and look-ahead. On a CAN/section-control build, the switch point is where the receiver thinks the implement is — so an offset error shows up as a section that starts a metre late, not as a curved line. If drift grows with speed, suspect latency and look-ahead before mechanics.
Do your drifts correlate with turns (that points at heading/lever arm) or with specific parts of the field (that points at RF or multipath)? That distinction usually names the cause.
