AgOpben + board 4.5 conectet via USB
Hi, I have a question. I have a standard board version 4.5 and I would like to communicate via USB (I damaged the Ethernet port in Teensy). How can I do this painlessly? Is there a ready made program? I only need it for RTK and IMU. I don’t want to make a panda when I have a board, and I don’t want to buy a new tensy.
could you show how you damaged the Teensi
I drilled 1 hole for the Ethernet pins (I wanted to remove the solder and used to big drill bit)
could you take a photo ?
