AgPath – record and name your runs (separate add-on, does not modify AgOpenGPS)
Hi all,
Well I didn’t made Claude did :smiley: but I tell it what do doo this message under is Claudes my English sucks! I need it for planting because we plant several products in one field and AGopengps missing this kind of option I don’t know if anyone else need it, but…
I made a small Windows add-on that runs next to AgOpenGPS and records the paths I drive. Each run is saved separately, so one field can have many layers, e.g. planting, spraying, harvest.
  • Start/stop button. When saving, you pick a product and variety from editable lists (e.g. Chinese cabbage / Produro) or type your own name.
  • It saves the path, date, start/end time, duration, distance and area. You get both driven area and covered area (overlaps counted once).
  • The field is detected from the AgOpenGPS boundaries, and the working width comes from the selected tool profile.
  • Optional filter: record only with RTK fix, or with fix + float.
  • Files are GeoJSON and KML (QGIS, Google Earth) plus a CSV summary.
  • There’s a built-in map viewer (OpenStreetMap, Finnish NLS maps or any XYZ tile service). It also writes a single self-contained HTML map file that you can share, e.g. through OneDrive, with someone who doesn’t have AgOpenGPS.
  • It uses the language and units set in AgOpenGPS (EN, FI, SV, DE, NL, FR).
It does not change AgOpenGPS or send anything to it. It only listens to the UDP data that AgOpenGPS/AgIO already broadcast on the local machine.
So far I’ve only tested it with AgOpenGPS 6.8.5 on my own tractor (RTK, a 1.75 m planter). The next field test for me will be in spring, so I’d be happy if someone tried it with other versions, wider implements or imperial units. There’s a test sender included, so you can try it without a tractor.
Download and guide: GitHub - Maco1981/Agpath · GitHub
Licence: Apache 2.0, same as AgOpenGPS.
Feedback and issues are welcome, here or on GitHub.
One useful test for the RTK filter would be a short loss of fix in the middle of a run. Does the saved path break at the gap, or connect the points across it? That could affect the covered-area estimate.
Hello, we did some test for it and yes it will loose area if it loose fix. So we did 3 different options to choose. All points, only RTK fix and RTK fix/float So it will be able to compensate if few points are weak or not were it should, but if you have good fix then all points is ok. We often have long distance to RTK base so sometimes losing fix is normal.
