AOG Field Editor – edit boundary points, flags, field origin and track names in the browser (testers wanted)
Another option would be to set it up so that when you open a processed field, clicking creates a full boundary around the worked area.
Thanks, glad you like it!
Something like this in AgShare would be possible, but not all the data is in the cloud. AgShare only has the boundaries and the AB lines/curves. Headland, tramlines, flags and so on stay in the field folder on the computer.
Export is a good idea, I’ll have a look at it.
Export is in now: KML, GeoJSON, Shapefile and ISOXML. ISOXML only has the boundary and AB lines/curves so far. Since you have more contact with terminals, it would be great if you could try it on one and tell me if it loads.
There is also an import now, so you can bring shapefiles or KML from other programs into an AOG field.
Thanks for the idea, it’s in! In the Boundary tab there is now “From coverage”. It puts an outer boundary around the worked area. With the sliders you can choose how exactly it follows the edge, and the ragged ends from turning become clean corners. Let me know how it works on your fields.
Update – import, export and boundary from coverage (same link: AOG Feldeditor)
Thanks for the ideas in this thread, a few of them are in now:
Export (Field tab)
  • KML (Google Earth), GeoJSON, Shapefile (ZIP, one file per layer).
  • ISOXML (TASKDATA.XML): only boundary and AB lines/curves for now. I can’t test it on a terminal myself, so if you try it on John Deere, Fendt, Claas, Müller … please let me know what works and what doesn’t.
  • Tick what you want to export: boundary, tracks, headland, headland lines, tramlines, flags, coverage.
Import (Field tab, or just drop the file on the map)
  • KML/KMZ, GeoJSON, Shapefile, ISOXML.
  • Coordinates are converted: WGS84, UTM, and the Austrian and German systems (MGI Lambert, MGI and DHDN Gauss-Krüger). I tested it with my AMA export, the boundaries match my AOG fields within about half a metre.
  • You see everything as a preview and click what you want. Then either make a new field from it or put it into the open field.
  • Files exported from the editor keep their layers: tramlines, headland etc. go back to where they belong.
  • You can even draw a whole field in Google Earth: make folders called “Boundary”, “Tramlines”, “Headland”, “Tracks”, “Flags”, draw inside them, save as KML and import.
Boundary from coverage (Boundary tab)
  • Builds an outer boundary around the worked area, for fields that were driven without a boundary.
  • One slider for precision, one for straight edges. The ragged turning areas at the ends become sharp corners, so a simple field ends up with just 4 points.
Smaller things
  • Delete a field completely (with a question first).
  • The field list on the left can be made wider.
As always: close the field in AOG before saving, the old files go to a Backup_… folder. Feedback is welcome!
:austria: Kurz auf Deutsch: Neu sind Export (KML, GeoJSON, Shapefile, ISOXML mit Grenze und Spuren) und Import, auch eAMA-Shapefiles und Felder aus Google Earth. Dazu Grenze aus der bearbeiteten Fläche und Feld löschen. Rückmeldungen gern, vor allem zu ISOXML am Terminal!
Update v2.1 (same link: AOG Feldeditor)
New this time:
  • Split a field: click two points, the field is cut there. One part stays and the other becomes a new field, or both become new fields. Tracks, tramlines and flags are split along with it.
  • Combine two fields: pick the second field, click two connection points on each side, done.
  • Import/Export: KML, GeoJSON, Shapefile and ISOXML (ISOXML only boundary + AB lines so far, terminal testers welcome!). Import also works with Austrian eAMA files and fields drawn in Google Earth.
  • Boundary from coverage and delete field.
All changes: Release v2.1 – Split/combine fields, import and export · SkaFUU/aog-feldeditor · GitHub
As always: close the field in AOG before saving. Feedback welcome!
:austria: Kurz auf Deutsch: Felder teilen und kombinieren, Import/Export (auch eAMA und Google Earth), Grenze aus der bearbeiteten Fläche, Feld löschen.
Do you think it would be possible to have a little display of how far (metres N & E) you’re moving a point, just as you drag it?
I’m imagining a process of walking the fields and making notes of required adjustments before executing them on the desktop.
Brilliant work!
Thanks, good idea! It’s in: while you drag a boundary point (or a flag), the editor now shows how far you moved it – the direct distance plus east/west and north/south in metres. It stays visible after you let go, until your next action.
Ideal, thankyou.
Small update: the tool is now called AOG Field Editor and has a new address:
Code / issues / releases: GitHub - SkaFUU/aog-field-editor: Browser editor for AgOpenGPS fields: boundary points, flags, field origin, layers and track names – no install (EN/DE) · GitHub
The old link still works and forwards you, but please update your bookmark.
Since the first post a lot has been added: headland and tramlines (calculated like AOG 6.8), tracks on all field sides automatically, split/combine fields, import/export (KML, GeoJSON, Shapefile, ISOXML), official aerial images for several countries, and a cut tool for tramlines. The README has the full list.
Feedback is still very welcome, here or on GitHub.
:austria: Kurz auf Deutsch: Neuer Name AOG Field Editor, neue Adresse oben. Der alte Link leitet weiter, aber bitte das Lesezeichen ändern.
