I am trying to get my Ardusimple SimpleRTK2B base station to NTRIP to RTK2go and am needing some help. I am using the Wifi Master cards to connect. It seems to be sending some data, but is not showing that it is sending RTCM data. I recently updated the ZED-F9P board to 1.32 firmware and used the base configuration file from Ardusimple. Only change I made was to the TMODE3. I set it to fixed mode and used the fixed position coordinates I got from running a 24 hour PPP scan. While connected to U-Center I can see RTCM data on the packet viewer. When I check the status on RTK2 go here is what it shows…
STR;NosttamBase;;;;0;;SNIP;USA;0.00;0.00;1;0;sNTRIP;none;B;N;0;
Any ideas why the RTCM data is not coming through? I have the RTCM 1005, 1074,1084,1094,1230 enabled on UART2 and USB. Also wanted to mention that I have used these boards since 2020 with a XBEE radio connection and have had good luck.
Thank you
