Building and hooking up a section control ability to a John Deere sprayer with AOG V4
I would like to see an option in AoG for mapping either according to the commanded section relays (like it is now) or according to a new feedback/confirmation PGN from the Arduino. For example, I have pressure sensors on each section, so I’d like AoG to map each section according to what my Arduino confirms using a new feedback/confirmation PGN. With this ability/option selected it should map regardless of what my auto/manual section control settings are in AoG. I am doing this now with an older modified pre v3 using my own custom PGN but I’m hoping to move to v4 soon but I don’t want to redo all the work each time there’s an update, would be nice to have it included in Brian’s copy.
No, my sprayer has no bus system.
@Wolle really like the look of this will suit my build perfectly! im creating a pcb based off your drawings and just wanted to clarify the position of the wires on the relays switch side. so far ive decided 12v from rate controller to the n/o pin and output to the section switch and optocoupler on the com pin. Is this correct or am I missing something? Cheers
