Um982 10Hz. On the photos of settings I don’t have RTK because I didn’t turn on wifi router on my phone. Also I use free availible RTK correction in Poland but the base is over 20km far away from me. Can it be a problem?
As del_boy said, the way screen jumps is not good. Last time I saw this happening was bricked BNO, it was working for 2 years in that position and than it stopped and it didnt want to zero anymore. It was mounted sideways(vertical) in a cab and than I had to move it horizontal… How is your PCB placed?
Yes, I’m 100% sure that my UM982 is running at 10 Hz, and AgOpenGPS also shows 10 Hz. The GNSS receiver is tracking a total of 54 satellites and outputs GGA, VTG and HPR messages.
I’m using an Adafruit BNO085, while the ADS1115 was soldered directly onto the AIO PCB by JLCPCB during assembly.
The IMU seems to be working correctly. It shows the tractor’s roll angle properly, responds correctly when the tractor tilts to either side, and has been properly zeroed and calibrated. I’ll try to check the Heading Chart and send some pictures.
Tomorrow I’ll also upload another video showing the steering behaviour on flat ground. I was still having some steering issues there, but the deviations were much smaller, around 0–3 cm, which would actually be acceptable for me.
And yes, I have already used SmartWAS to calibrate and zero the wheel angle sensor.
Does it roll to the right direction? I.e. left and right are not swapped?
How’s your box positioned?
If connector comes out to the back or right you’ll need invert IMU.
If connector is sideways then axis is Y not X.
