Hi,
3 years ago I installed a aog set-up with single antenna and IMU on my tractor. Now I want to do a dual antenna installation on another tractor with keya motor.
I have a PCB AIO micro v4.2 and I’m not sure what I have to buy. I need :
-2 F9p and 2 antenna
-teensy 4.1 ethernet
-keya motor
Am i right ?
Bepe
November 2, 2026, 6:02am
2
Better buy 1x UM982, cheaper and more compact for dual antenna build.
All right !
The UM982 has the same size and the pins can be plugged in the space normally dedicated to the F9p ?
Do I need something else ?
Bepe
November 3, 2026, 6:35am
4
I use other PCB, do not know if if fit right away. But if you search the discourse and telegram I am sure you find how to do it.
Ebedel
November 3, 2026, 1:18pm
5
The micro um982 fits perfectly in the spot of f9p
Here is the kit
It works as good as two f9p ?
I have read that, for some people, it doesn’t work as well.
Ebedel
November 4, 2026, 1:13am
7
I’d say um982 duel antenna works better than duel f9p .
Configuration might be a bit harder to figure out but performance is better
Allright, is there any tutorial or video to configure the um982 ?
Some people have luck using configomatic some dont so maybe try that 1st
Ok, is there any special firmware for the teensy or I can use the one for f9p ?
Ebedel
November 5, 2026, 12:16am
11
Use a one of the keya firmwares for the teensy
Some where there’s a keya lazy kickout firmware that works really well, it might be the standard keya version now… someone else might know better!
del_boy
November 5, 2026, 7:19am
12
Teensy firmware for dual um982 is hit and miss on configomatic. I believe one of the keya sketches will work.
Dual um982 uses different messages so teensy needs to see the same. Majority of firmware is for single gps and imu
Can you tell me where I can find the firmware for dual antenna with um982 ?
del_boy
November 6, 2026, 7:43pm
14
If you look on gunicsba github
Search for his firmware and use the keya lazy kickoff with auto discover
