Hi! Can those with experience confirm the observed voltage coming out of RQH100030 as the main arm is moved. Readings taken without involving the extended arm.
That is normal readings with hall effect angle sensors.
Just install it so you use one of the 90deg sections that the volts change. Don’t use more than 90deg but try use 80deg of the movement.
k thx
