Fallback from DUAL to Singel+imu (and imu fusion)
I did not have this issue with imu not connecting. Have you tried your setup with a panda firmware? Is the reverse detection activated?
I tried to implement an prevention to that um982 sometimes flip heading. Could be the problem if imu is not connecting.
i will check imu on serial than will post here again
I did some test while spraying. I think it steers better with more imu. I contacted Unicorcomm and got some alternative settings for um982 to improve DUAL.
I will test them when I get the time.
rotation issue resolved by changing the IMU clock speed from 400,000 to 100,000 in the firmware.
IMU is now detected properly and the continuous rotation has stopped. I tested this while parked, and will field-test it soon. I will update the thread here after field test
tested firmware v0.3 on the field. The HEADING_ALPHA works perfectly—both 0.00 (pure HPR) and 1.00 (Single+IMU) are stable.
but problem with ROLL_ALPHA fusion. My setup requires the IMU roll to be inverted, but the DUAL roll works correctly without inversion. When I use the monitor to invert the IMU roll, it also inadvertently inverts the DUAL roll. Consequently, I can’t fuse them because they are always “fighting” each other (one shows positive roll , the other negative roll ).
At least some progress :slight_smile:
I also noticed that the sign convention is wrong. Inverted roll roll is needed when the axis is pointing forward. I will try to fix that.
I do not have your issue with IMU. (I use a BNO085). Googled and found that it could be a problem. It´s great you could get it going. Probably a good thing to add a comment in the firmware.
Here is an example where you do not need to invert roll to make it work. Beware that I have not had the time to test it myself. Made som other cosmetic changes to the monitor as well. Please let me know better or worse :slight_smile:
um982_monitor_V0.4.zip (8.3 KB)
000_UM982_Fallback_V.04.zip (55.7 KB)
Thanks for updated ver …i will test & will update here
i tested v04.. its work fine but can not mix roll as invert roll still having same issue … if invert roll from moniter its invert both roll dual and imu roll … without roll invert from moniter dual roll is okay left side up is + roll and imu roll is opposite left side up is - roll … if i invert roll from monitor its gets both inverted left side up dual roll is - and imu roll is + … invert roll from monitor needs to invert roll of only any one dual or imu not both
Thanks for testing, I just do not have the time to test it myself at the moment. Here is another untested version. I found some errors…I hope this will solve the problem.
um982_monitor_V0.5.zip (8.4 KB)
000_UM982_Fallback_V0.5.zip (55.7 KB)
thanks for update… i will test it soon
Thanks for the updated version 0.5. I tested it on my tractor today, and after inverting the roll from the monitor, both the IMU and DUAL roll matched perfectly and the system worked well. I plan to test it for longer durations in the field now, and I think it will work great. Thank you!
That’s good news. I think it will be possible to start optimization of the settings in the monitor.
Did you test the “add dual function” at U-turns?
i didnt test dual function at U-turns yet as it was just short run for testing imu and roll… will test it while full day run
The development took a turn to be a general software. Continues here: General Firmware for Teensy
