How I setup RTK Base Station using Agopen to feed SNIP and broadcast on Rtk2go
No that one should not be enabled only those 5 needs to be enabled. It seams that you didnt save config.
Follow instructions on ardusimple site when you upload config go to messages to check if only these 5 messages are enabled on UART2. If its all good save config
Config as ardusimple instructions and “UBX-CFG-CFG” → Send
Google Photos
Now base is set go back to wifi ntrip master and try connecting, set setting in ntrip master config UART0 and set ip to dhcp try connecting to rtk2go.
Change in lights
Ok
Google Photos
Google Photos
Thank you Radmuffins!
Google Photos
Google Photos
I am setting up my base station using my ublox F9P feeding into SNIP then to agopengps. I have my registered base station name from RTK2Go. I have followed steps 1-7 and in SNIP set my data format to Auto detect w parse. In SNIP my serial stream is inputing data(I assume from my F9P) butwith no output. My pushed-out stream connection says Data Starved. In Agopengps my MOUNT is not listed and such I cannot connect.
Anyone have any suggestions what might be wrong? I assume it is a setting somewhere.
Perhaps it’s this maybe (part 7 but Data format is Auto Detect w/Parse, and the rest of the settings leave as default.
Edit: “Enable logging” off obviously)Kaupou said this to me but I find logging made no difference.
Its a while since I did this, I will read through and see if I find a reason.
Kevin
Thanks Kevu. I will try these settings.
