How to construct a ground base station using UM982
There are several uncertain issues:
  1. How to quickly obtain benchmarks without using network RTK;
    Currently, we are using the PPP-B2B model for acquisition, with a time frame of 25-35 minutes. The manufacturer’s time is 12 minutes. For the same sentence, how can we troubleshoot it.
  2. How can a base station simultaneously save observation data and broadcast differential data in real-time; and save observation data for PPK processing.
  3. Are the two modes of “first 1, then 2” conflicting
  1. you can easily configure UM982 to output RTCM data to a public NTRIP caster to set up your own nearby RTK base station, assuming you have a UM982 evb board or on a Evk. ppp-B2B takes about 20-30 minutes to converge to PPP position fix ( e.g. cm level accuracy)
  2. it’s can be easily done again with a UM982 on a evb, you only need a piece of software to upload the serial output(configured to have RTCM on this port) to save the data on your PC, and meanwhile push the data to a public NTRIP caster.
  3. not sure why first 1, then 2 is needed.
