Hunting the line
Twice now in the last 150 acres I have planted I will turn off steering at the end of the pass, turn about half way around or more until AOG is indicating it has found what should be the next pass, hit the steer button again and AOG will hunt the line. By this I mean it will over react compared to usual to get centered on the line. I will require 3 to 5 left right steering maneuvers each decreasing in intesity before it gets to steering correctly. This will happen on each pass until I shut down the version 4.5 board and restart it. It will then go back to normal and work well for the rest of the day. Any Ideas what might be happening here? How might I go about figuring out what is happening? It’s not a difficult fix but would be nice if it didn’t happen. When everything is working I don’t know how it could work better.
