I found the form for this and built a solution with an upper limit of 400cm for the boundary contour mode. But wondering if it would be worth increasing upper limit for future releases? Lets you use the boundary for guidance in some weird settings. Or in my case, off centred field boundaries.
I can certainly make the spacing setting in the “Make Contour From Boundary” form to anything. Is 4 meters enough? You can also make multiple tool widths from the edge as well - it can be a long way from the edge.
I set it to 20 meters. Will be in the next release which won’t be long
Fantastic. 4 meters is plenty, and 20 is even more so. Thankyou.
