Keya, Witmotion UM982, AIO Firmware?
What is the correct firmware I need to install on the teensy for a Keya and UM982 system? What configuration does the UM982 require?
Single or dual?
For Single configomatic will do the um982
For dual you need to copy and paste the dual configuration into uprecise
If your using Single the lazy kickout keya sketch works well on balaize github
Going to be a dual setup. Where might I find the correct configuration to copy and paste?
If you go into the configomatic firmware folder its in there under dual um982 its a txt file
If you look on gunicsba github all the keya firmware is there for single and dual
Thankyou for that
