Lemken LGT-750 vs Trimble GFX-750
I recently bought a used Lemken Solitair 9 seed drill, equipped with an LGT-570 terminal - Solitronic v 1.20.
I have a Trimble GFX-750 navigation system in the tractor.
Do you know if it is possible to connect the GFX-750 to the LGT-570?
The LGT-570 in theory accepts a GPS signal, but the question is how to switch from the GFX-750 to the LGT-570?
Or maybe it is worth adding an ISOBUS gateway for Lemken? Have you added such a solution? What will ISOBUS give us in the Lemken solitair 9?
Best regards,
YacentY
