Load sensing OC steering
I was talk about the engage switch, so you don’t have one? You are using the one on the screen?
I don’t know if this work with an disengagement device, never tested. Try button or switch in the AOG settings or modify the ino or install a physical switch.
I think your problem is there somewhere, not on your pressure switch.
Ah OK I will install a button and see how that goes thanks for your help.
