Anyone hook AOG up to the B5589 kit? I have a couple of questions.
How to hook up the solenoids on the valve block? In this document on page 4 it says the connector is E1 or E2.
Datasheet_PRM2-04_ha5105_EN.pdf (484.6 KB)
In this document on page 18 it says one pin is “coil housing ground” and the other two are DC + or -.
Datasheet_Coils_ha8007_EN.pdf (782.6 KB) Is this correct?
How to hookup the lock valve? This document on page 5 show 2 pins. It doesn’t say which is + or -.
DLDAXHN912_full_en_us_letter.pdf (193.0 KB)
Here is some info I have on the kit:
1.
WAS Honeywell RPNS090AA1B11A
pin 1 ground
pin 2 10 Vdc to 30 Vdc
pin 3 4.75 Vdc to 0.25 Vdc signal
Connector 282087-1
terminal 282110-1
seal 281934-4
hydraulic valve
PRM2-043Y11/04-12
Lock valve
DLDA XHN Sun hydraulics
connector Deutsch DT04-2P
wedge W2SA
pressure sensor
MLH500PSB01A Honeywell
5V power supply
0.5 Vdc to 4.5 Vdc
connector Metri-Pack 150 with shielded cable, Honeywell 3685302
- 12065287, Mouser 829-12065287
terminal
- 12048074-L
cable seal
- 12065285
a 5Vdc
b output
c ground
Kit instructions:
Macdon Autosteer kit B5589.pdf (5.4 MB)
