Good morning,
Has any UK dweller got a PCB parst list with RS product codes? Would save a bit of time!
Good morning,
Me i use linear regulator instead dc dc regulator
Manufacturer Part Number | Manufacturer | Digi-Key Part Number | Customer Reference | Quantity | Unit Price | Extended Price | Description | ref RS | price | quantity | to be order |
VX7805-1000 | CUI Inc. | 102-4253-ND | 2 | $4,70 | $9.40 | DC DC CONVERTER 5V 5W | 2988508 | 5,2 | 1 | 2 | |
C320C104J5R5TA7301 | KEMET | 399-9867-1-ND | 10 | $0,45 | $4.50 | CAP CER 0.1UF 50V X7R RADIAL | 181-4752 | 0,294 | 50 | 50 | |
LTL42EKEKNN | Lite-On Inc. | 160-1665-ND | 2 | $0,68 | $1.36 | LED RED CLEAR T-1 T/H | 451-6593 | 0,162 | 5 | ||
1N5401RLG | ON Semiconductor | 1N5401RLGOSCT-ND | 2 | $0,60 | $1.20 | DIODE GEN PURP 100V 3A DO201AD | 628-9451 | 0,41 | 10 | 10 | |
1N4004RLG | ON Semiconductor | 1N4004RLGOSCT-ND | 4 | $0,28 | $1.12 | DIODE GEN PURP 400V 1A DO41 | 6289029 | 0,166 | 10 | 10 | |
CB1-P-12V | Panasonic Electric Works | 255-1832-ND | 2 | $7,80 | $15.60 | RELAY AUTOMOTIVE SPDT 40A 12V | 8155094 | 1,83 | 1 | 1 | |
110-87-306-41-001101 | Preci-Dip | 1212-1002-ND | 4 | $0,58 | $2.32 | CONN IC DIP SOCKET 6POS GOLD | 7020657 | 0,358 | 5 | 5 | |
35PX1000MEFC10X20 | Rubycon | 1189-1745-ND | 4 | $1,04 | $4.16 | CAP ALUM 1000UF 20% 35V RADIAL | 7639438 | 0,568 | 5 | 5 | |
CF14JT330R | Stackpole Electronics Inc | CF14JT330RCT-ND | 15 | $0,06 | $0.90 | RES 330 OHM 1/4W 5% AXIAL | 135-825 | 0,017 | 10 | 20 | |
CF14JT1K00 | Stackpole Electronics Inc | CF14JT1K00CT-ND | 15 | $0,06 | $0.90 | RES 1K OHM 1/4W 5% AXIAL | 267-1654 | 0,91 | 10 | 20 | |
282857-3 | TE Connectivity AMP Connectors | A98360-ND | 4 | $2,43 | $9.72 | TERM BLK 3P SIDE ENT 5.08MM PCB | 7100371 | 1,018 | 5 | 5 | |
282857-2 | TE Connectivity AMP Connectors | A98359-ND | 2 | $1,87 | $3.74 | TERM BLK 2P SIDE ENT 5.08MM PCB | 7100100 | 0,387 | 5 | 5 | |
4N33 | Vishay Semiconductor Opto Division | 4N33VS-ND | 4 | $0,92 | $3.68 | OPTOISO 5.3KV DARL W/BASE 6DIP | 919-0060 | 0,328 | 10 | 10 | |
2 | support arduino | 1981501 | 1,4 | 1 | 5 |
I didn’t save time and searched the manufacturer part numbers on RS, as well as DigiKey, Mouser and a few others. Most of my components ended up coming from Mouser. Prices and availability have probably changed quite a bit since then. For most parts there wasn’t that much price difference, but there were a few items where some suppliers either didn’t have stock or could be twice the price of the cheapest.
If you buy enough components to get 5 PCBs build up then the order is plenty big enough to split up and still get over the free delivery requirements on all of it. Just takes a bit more time and effort to sort it all out.
I ended up ordering the bulk from digikey, but had problems finding the relay socket and some other parts anywhere in the U.K. so ended up bulk ordering from EBay.
