Hi, I’m having trouble with the pcb shorting when I connect the steer switch? I have readings from the WAS and power to the motor but when I connect the steer switch to engage drive the relay makes a noise and power to pcb is lost. Tia
what PCB ? where did you connect wires for steer switch?
for PCBv2 you need to connect to 0 and com pins (2 and 3).
Thanks! Got the motor driving but only wants to steer to the right?
Try inverting WAS and/or motor in AOG to find combination that works.
It’s recommended to watch videos for first setup and you have manual in support folder to help you.
