# Plug and play
**URL:** <https://discourse.agopengps.com/t/plug-and-play/9421>\
**Category:** Uncategorized\
**Created:** [26 May 2022 23:16 UTC](https://discourse.agopengps.com/t/plug-and-play/9421 "2022-05-26T23:16:44Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![elmosindustries](https://discourse.agopengps.com/letter_avatar_proxy/v4/letter/e/ad7895/32.png) [@elmosindustries](https://discourse.agopengps.com/u/elmosindustries)\
**Post date:** [26 May 2022 23:51 UTC](https://discourse.agopengps.com/t/plug-and-play/9421/2 "2022-05-26T23:51:39Z")
</div>
There is a bit involved in setting everything up. Youtube and the posts on here are your friend though.
> [@Autosteer basic configuration](https://discourse.agopengps.com/t/autosteer-basic-configuration/8848):
> One of the most important settings is the basic Autosteer settings. In this document we will try to guide you to get everything working correctly. STEP 1: Open Auto Steer Configuration window, click in degrees icon information and a new window will pop up. If you press on the lower part of the window, it expands, showing new functions for the configuration, there are a total of three expansions, that pressing on that part again appear or disappear, in a cycle. La…
> [@Upload ino on an Arduino](https://discourse.agopengps.com/t/upload-ino-on-an-arduino/8833):
> This guide is a step-by-step (with pictures) on how to upload on an Arduino using a Windows 10 machine. Go to last version of [AgOpenGPS](https://github.com/farmerbriantee/AgOpenGPS) Download AgOpenGPS.zip (this file contents last program files) and SupportFiles.zip (this files contents ino files, PCB desings, wirings, …) Step 1: Connect Arduino using a USB Cable A separate power cable is not required; the USB connection to the computer will power the board. Step 2: Download and install Arduino IDE The IDE (Integrat…
[https://discourse.agopengps.com/t/f9p-firmware-update-and-config-files/8830/6](https://discourse.agopengps.com/t/f9p-firmware-update-and-config-files/8830/6)
> [@Wiring diagrams](https://discourse.agopengps.com/t/wiring-diagrams/7907):
> As part of the documentation we have created this post to have grouped all the wiring diagrams for the PCB. We use the Kaupoi 4.1 PCB for the diagrams, but it can be used for any current PCB, you just have to look at the names of the connections on the PCB. The only difference is that the Kaupoi 4.1 has a slot for the Adafruit BNO085 and a slot for the CMPS14. Later you will find diagrams to connect any BNO08x that is not from Adafruit. The difference between the BNOs is that Adafruit uses a v…
_[View the full topic](https://discourse.agopengps.com/t/plug-and-play/9421)._
