QtAgOpenGPS lives... and needs a new name
I sent you a DM. Let me know if you didn’t get it.
Oh and if you’ll send me your github username, I’ll check out your change. We’ve been using git to share instead of github, then pushing to github.
I’ll go git remote add tenteen [url] in the terminal, then git pull tenteen [branchName] then git push to my github.
So instead of your git branch → your github → my github → my git branch, the sequence is more like:
Your git → your github → my git → my github.
Saves us having to do much with github, and has worked well so far.
There is no such thing as multiplatform. Its a terrible and timeconsuming work to make connections work on all platforms. The code is full with if and else.
Yes that’s often the case. But so far Qt has provided enough abstractions that we have only maybe one ifdef in the entire code base. Not too bad! Coming from a Unix background I’m quite used to the idea of portable programming, so I’m not too surprised Qt makes it work so well.
QtAOG does build and sort-of runs on Windows, Linux, and Android. x86 or ARM. Probably macOS too, but I’ve never tried it. So that’s pretty good. There are some android-specific things that will require a bit of ifs and elses, including dealing with different screen orientations and sizes, and dealing with the onscreen keyboard. But those are things Android developers have to deal with anyway, even if they use “native” tools. There will also be issues with the serial port on Android which will require platform-specific code when we get finally to AgIO, next winter.
Its working with the excellent GitHub - mik3y/usb-serial-for-android: Android USB host serial driver library for CDC, FTDI, Arduino and other devices.. Maybe you must add devices to the prober.
At the moment I’m testing an Expo/ReactNative version of AgIO.
Great work! That’s awesome!
Will there be a version of AgIO in qt6? I need a way to get data from my GPS into the qt6 version of QtAoG running on Linux.
It is under development.
Yes. I have a qt cpp version of agio on my fork right now. It hasn’t yet been merged into @torriem s fork yet, and is very much still under development. It’s only CLI based right now, and really all that works is the UDP code… No USB, no NTRIP, no auto reconnect. If you lose UDP connection of any sort, you have to restart. But here it is if you want to try.
I started working on the agio side a few weeks ago and it was actually my first attempt at CPP coding, other than some Arduino work awhile back, so definitely isn’t just easy coding!
People like pictures…
Some have been asking about QtAOG, so I thought I’d put a quick note on here… QtAgIO is very much alive. UDP and NTRIP at least halfway work. I had it steering our tractor for .5 km today. The process to get it going was rather long and complicated and involved sending the steer settings via AOG and then switching out to my mint OS laptop. And editing the .ini to set the correct WAS offset. And even then the tires steered too excessively to really be useable. But having it steer for that far did feel like an achievement!
QtAOG: There’s still a lot of little things that need to be finished. A few not totally necessary pages that need to be completely designed. Probably the most major is it’s still the old V5 pre tracks code. Tramlines and flags are non existent. Field, boundary, headland creation should all work. The line creator doesn’t exist. Youturn doesn’t work. Vehicle creation should work. I think all the vehicle settings work except for the WAS offset, and the Arduino steer settings. (When I say work, I mean that we can change in the UI and the.ini file changes. There’s still quite a few of the main buttons that don’t function yet.
Torriem is in the middle of harvest now, so he is busy right now. Come winter, I think we’ll catch up QtAOG with v6. However, I don’t have sufficient cpp knowledge to do that on my own.
QtAgIO: Thanks to @tenteen for creating the basics so I had something to work with! As of right now, the NTRIP, UDP, NMEA, and the scan reply code backend works. The frontend has the four main module indicators connected. And a button for setting the subnet. I haven’t gotten the settings connected to the frontend yet, so all the settings have to be set in the.ini.
So. Progress has been made. But I’m not fast, learning both CS and cpp as I go along.
I was going to keep this short, but I think I failed :slight_smile:
Well done!
You know I always want to help.
I finally got decent build instructions for linux on my repo wiki here. If someone has an idea of how to improve, let me know, or add it. :slight_smile: They include how to download QT6 from the internet, and follow to running QtAOG on a desktop to creating .apks on android.
I also got .apk’s created for both QtAOG and QtAgIO. They’re not really useful yet, but look kind of neat. Android use in the field has a ways to go yet. The two programs idea will have to go, or get seriously redone. Not being able to see both QtAOG and QtAGIO at the same time is a real pain. And we need the correct code to allow a program to run in the background. APKs are on google drive if anyone is interested. QtAOG Binaries. - Google Drive
For now, android isn’t really the main thrust. Debugging is a pain, so there’s no point in really trying to get it to work until QtAOG works well on a computer OS. Then we’ll focus more on android.
I’d like to hear from someone who has built QtAOG on windows! The build instructions should be fairly close to linux, but could vary slightly.
we continue to work on qtaog. at the moment we are working on expanding the functionality. Adding support for the blockage control for the seeder. suggest your ideas.
Video
I also have a bit of news… As of two minutes ago, I got the bluetooth code working. We can now connect to a bluetooth receiver (provided it’s paired to the computer), and read the location. NTRIP isn’t working yet. Also, once you try to connect, it adds the bt device name to a list that is saved in the settings, and will automatically connect to that name in the future. If anyone wants a try, have a look at GitHub - Davidwedel/QtAgOpenGPS at bluetooth
Also… If someone wants a challenge, try thinking up a way to connect any bluetooth device, and figure out a way to tell what data it is sending(I.E., GPS, Steer, or machine), store it in a buffer, and send it to QtAOG! I’m passionately against the idea of four or five ports that Mr User has to manually connect to, to send the correct data to the right spot.
Also… We’ve expanded and improved the wiki to include instructions for windows, as well as compiling for android. See Home · torriem/QtAgOpenGPS Wiki · GitHub
