You only have the message 1084 enabled. The position is given by the 1005. Also, you need a few other ones to get a RTK fix. This was discussed here.
Indeed, you enable them using U-center :
The value you enter is the transmission period. Use 1 s for all messages, except for 1005 which can be send at 10 s period with no negative incidence
