Set up your own caster without the usage of rtk2go.com
Tailscale makes it extremely easy to do. Free too and doesn’t use a central server.
Is there any secret to connect to rtkdata?
I’ve been trying to change my base from Rtk2go to rtkdata but just can’t seem to make it work.
Can you see your base’s data in your rtkdata dashboard?
No nothing showing up there and says offline.
@davidroberts30
Should the address be all lowercase?
And is the / required after the mount point name?
Is it really active? Can’t find it.
Nothing special required your mount point in capitals no /
I left my rtk2go stream running and just add the second rtkdata.online sending to port 2101
but on your rovers you will use 10057 looking at your picture
Okay thanks I’m using WiFi ntrip master and can’t see a way to have 2 stream’s running.
Put that info in exactly
On my f9p a d wifi master just swopped the info with the rtk2go info
Okay thanks all,eventually got working after deleting my base from rtkdata then re registered with new password and connected no problem.
Connection seemed very stable with very low RTK age.
Update so far after couple of days spreading manure I haven’t had any dropped connections with rtkdata.online.
Hello all, I am also trying to use rtkdata.online and I have not been able to get Uprecise to connect. Any suggestions?
Does anyone know the ip address of rtkdata.online? It seems UPrecise is unable to use the web address and must use the ip address. I am currently trying to use rtk2go but of course now that I need to be out in the fields rtk2go is not working.
You can look it up: Network Tools: DNS,IP,Email
Appears to be 82.146.60.24
Thank you so much. I have been beating my head against a wall trying to get rtkdata to work. Put the ip address in and now it is working.
I think you can enter the name in the agio ntrip form and it will show the IP?
