So I updated to 4.3.10 and it won't steer
Hi Confused
So where are you in this long proces ?
Did you manage to get it to work after the burn, or what really happened.
When you post it so many places it is hard to follow you.
Did you upload the settings from AOG to nano and with correct motor driver and other settiongs? (it is named: send to module.
Did you before that upload to Nano, the autosteer_usb_4.3.10 ino from support folder (with arduino program)
So I updated to 3.4.10 and it won’t steer
It is and thanks Edit This has all been done on mine so I guess I’m up a creek
1 day
Even in the drive tab what do I need to do to fix it I know it’s not the motor driver or connections to the nano My nano still gives me all the data from the ADS so I don’t think its blown but I dont know for sure It shows that my steer switch is enabled (it has a 5 in the “from module” line) I’…
4 days
Help with a blown PCB
Autosteer
I have the WAS connected and working What are these other settings?
4 days
Autosteer
The pcb still powers up but it won’t steer it gives me all the readings and such but it won’t steer I think I’ve narrowed it down to either the nano or the motor driver and I’m really hoping it’s the motor driver because I soldered the nano in without the plugs because they were backordered so now …
4 days
Bugs v4.3.10
Bugs-requests
We have as many half sections as quarter sections on our farm
21 May
Autosteer
O I meant to ask will it still steer with that wire blown? Because that’s why I noticed in the first place is because it wouldn’t steer
21 May
Autosteer
No it’s not
21 May
Autosteer
Ok so I’ve been looking at schematics some more and I’m not sure that that connection is even doing anything even so I have put wires in where I think they will connect between it [15900307567042425742857692011604]
21 May
Loss of USB connection Autosteer Module
Getting Started
I dont know I’m using a valve and very tiny wires seem to work fine I’m usi
