Spinning screen
Yes. I had to change a few other things as well. I haven’t gotten a chance to test it yet but the sketch verifies.
Veo en el video que las sentencias procedentes de tu gps no son estables, hay momentos en los que las horaciones desaparecen y cuando vuelven tienen un aspecto extraño. Que receptor gps usas?
Ublox c099 module with Trimble AG25 antenna. I have changed my setup since that video. Using a modified version of Brian’s sketch to run Cytron md13s driver on Danfoss valve. Still having to use v4.1 in aog but no more crazy nmea, as far as I can tell.
Debes configuar con U-center el protocolo de salida a solo NMEA, y en el puerto de salida que utilizas desactiva todo tipo de mensajes excepto GGA y VTG.
Yo utilizo la ultima version de AOG y las raciones del gps son estables. Tengo frecuencia de 8hz y correxcion a 1hz (en pestaña DATA SOURCE).
I am currently using AOrtner rover config set at 8hz rate with only GGA and VTG. Is rtk rate 1hz from base module what you mean as correction ?
Where is DATA SOURCE tab located ?
Click on the gear button and it shows you a lot of menu’s including data sources
Oh, I thought he was talking about ublox.
Cesar, no I am on 10hz in aog, as that’s what I remembered Brian saying to set it at. I had it set at 5 once and the steering was real far behind. That was before rtk though.
