Hello whats the name of the Sensor?
Can I use RTY270LVNAX?
Not a good choice. Picture how you should connect the rods to move it 270 degrees. ( well a wire on a wheel could work
You must make it in a way so you get the sensor to move its full scale. I use a 90 degree Honeywell, but 120 can work too.
This is in stock. I will use some other sensor, but I have ti fit it on other place.
The 270 version would work, but you will only be using a fraction of its sensing range if mounted like most WAS are. This will effectively give it a lower resolution with courser steps between the angles it will measure.
The counts per degree will need to be set to somewhere around a third of what most other people use, but should still be better than if you tried using a 90 degree sensor with the nano’s built in ADC.
I took a WAS photo of the Trimble steering system today, it uses Elobau, I think it might be of use to someone.
I’m using elobau WAS too, works perfect. i.e. elobau 424A06A120
so yours is 120 degrees.
Yes, perfect for my wheel angel -55 … 55°
I am having a hard time locating a wheel angle sensor in the USA. Seems like the Delphi ER10031 is being discontinued or is out of stock. I have been using them but would like and alternative. Is there another unit that someone is aware of that is available in the USA? Should I not be looking for hall effect sensors?
The Delphi ER is used as the ride height sensor on all 4 corners of many GM cars, I can’t believe that the sensor is going away anytime soon.
There are a bunch of different ER part numbers, they are all the same sensor with different length arms and linkages.
Search rock auto for delphi ER* and you’ll find GM part numbers. I believe the least expensive Cadillac model is around $50, I was able to get mine at Carquest and it was in stock.
I like the Delphi sensor because it is fairly robust, can handle a large arm, and has a stout return spring to take up any linkage slop. It’s not suitable to mount in a kingpin, but it’s great for linkages.
is this fore the sensor your selling, and the was sensor i recieved from you. Got 5 pins can you suply a discription. how to conect the sensor to the pcb.
Hello.
I have few questions about the DELPI Was.
What kind of plug do you use to connect it or have you a reference ?
What is the max angle ?
Or have you a data sheet ?
Best regards
There’s some info here
Thanks a lot !! ![]()
So I mistakenly bought this one AIR SUSPENSION HEIGHT SENSOR REAR RIGHT LAND ROVER DISCOVERY 3 RANGE ROVER SPORT | eBay
“Reference OE/OEM Number
LR020161, LR020161G, RQH500043, RQH500043G”
Any good? Is there a way to test to check?
