Teensy 4.1 issue
I bought 4 - teensy 4.1 from robot shop, and all of them have the same problem. Pin 32 (steer switch) doesn’t respond. Is this a common problem?
May I ask how are you testing it? You stick it in AIO Board and try? Are you connecting GND to steer switch pin? Do you have optocouplers soldered on the board?
I am using a standard 4.5 AiO, using the switch on the board and connecting pin 32 to ground , same response, I plugged in a different teensy that I know works. And that one works as expected but when i try new teensy with same firmware, it doesn’t respond.
I bought more now see if those work.
Have pushed the AOG settings to the new board via send and save? Change AOG to none and send back to switch and send. Some versions seems to help rebooting teensy after sending.
