Teensy Flasher
Hello all, I am getting ready to flash my teensy with the ConfigOMatic and would like to verify "Keya Motorwheel (Non-RVC - use this!) is the correct version to use for an AIO V4.5 using a Keya motor.
yes it is
In the Keya firmware is there a way to get 12V on the lock pin? I have a lighted momentary switch and would like it to light up when auto steer is engaged. Currently I don’t see any voltage on the lock pin. I am guessing that bit of code was left out of the Keya firmware since the lock pin is not typically used.
