Tracks from multiple fields
Is there a way to get tracks from mutiple fields combined?
Example- you have 3 fields side by side and want to use the tracks or ab line from the edge of the two on both sides when working the middle one?
Only way i have found now is to copy the 1st then delete boundaries and keep the lines but i forget to do that on the other so i cant get them all together?
You can export the tracks as kml(?) and import them back in?
Thanks I’ll give it a try
