Ok here is my configuration (to be tested)
I use “Coolterm” as terminal
First configure Coolterm:
In the “Option”, in “Terminal” I change “terminal mode” to “Line Mode”
In “Transmit” I check “Use transmit line delay” and set to 30 ms
In “Connection” press “send string” to open the send window
Now follow this:
config dual UM982 with Has capability
//to see version firmware
//type:
VERSION
must be firmware 13495
//type:
FRESET
/// this reset all settings, set bautrates to 115200 and disable all outputs (I think)
////reconnect if necesary with 115200
//type:
CONFIG RTK RELIABILITY 3 1
CONFIG SMOOTH RTKHEIGHT 0
CONFIG HEADING RELIABILITY 3
CONFIG HEADING VARIABLELENGTH
CONFIG SMOOTH HEADING 0
CONFIG HEADING OFFSET 90
CONFIG RTK TIMEOUT 120
CONFIG COM1 460800
MODE ROVER SURVEY
GPGGA COM3 1
GPVTG COM3 1
GPHPR COM3 1
KSXT COM1 0.1
SAVECONFIG
////then type:
CONFIG SIGNALGROUP 3 6
////then type:
CONFIG PPP ENABLE E6-HAS
SAVECONFIG
////type "CONFIG" to see if all is OK
////should look like this:
$command,config,response: OK*54
$CONFIG,ANTENNA,CONFIG ANTENNA POWERON*7A
$CONFIG,NMEAVERSION,CONFIG NMEAVERSION V410*47
$CONFIG,RTK,CONFIG RTK TIMEOUT 120*69
$CONFIG,RTK,CONFIG RTK RELIABILITY 3 1*76
$CONFIG,SMOOTH,CONFIG SMOOTH RTKHEIGHT 0*66
$CONFIG,PPP,CONFIG PPP TIMEOUT 120*6C
$CONFIG,PPP,CONFIG PPP ENABLE E6-HAS*01
$CONFIG,HEADING,CONFIG HEADING OFFSET 90.0 0.0*10
$CONFIG,HEADING,CONFIG HEADING RELIABILITY 3*67
$CONFIG,HEADING,CONFIG HEADING VARIABLELENGTH*3E
$CONFIG,SMOOTH,CONFIG SMOOTH HEADING 0*7C
$CONFIG,DGPS,CONFIG DGPS TIMEOUT 600*69
$CONFIG,RTCMB1CB2A,CONFIG RTCMB1CB2A ENABLE*25
$CONFIG,ANTENNADELTAHEN,CONFIG ANTENNADELTAHEN 0.0000 0.0000 0.0000*3A
$CONFIG,PPS,CONFIG PPS ENABLE GPS POSITIVE 500000 1000 0 0*6E
$CONFIG,SIGNALGROUP,CONFIG SIGNALGROUP 3 6*01
$CONFIG,ANTIJAM,CONFIG ANTIJAM AUTO*2B
$CONFIG,AGNSS,CONFIG AGNSS DISABLE*70
$CONFIG,BASEOBSFILTER,CONFIG BASEOBSFILTER DISABLE*70
$CONFIG,LOGSEQ,CONFIG LOGSEQ 1*15
$CONFIG,COM1,CONFIG COM1 460800*2E
$CONFIG,COM2,CONFIG COM2 115200*23
$CONFIG,COM3,CONFIG COM3 115200*23
Here is a video on Youtube
