Using AGOpenGPS with a joystick
Click build AgOpengps in build section if it is successful click publish then install and copy .exe to existing aog install. Not ideal but it works.
Switch from debug to release.
Hello, maybe also usefull:
        // AB-Line aktivate
        if (keyData == (Keys.K))
            btnABLine.PerformClick();
            return true;    // indicate that you handled this keystroke
        // AB-Curve aktivate
        if (keyData == (Keys.I))
            btnCurve.PerformClick();
Does someone know how to implement:
  1. U-turn Left / Uturn Right button
  2. Drive in
         // drive in
         if (keyData == (Keys.E))
             btnInField_Click.PerformClick();
btnInField_Click.PerformanceClick() does not work:
Failure: btnInField_Click is not declarted
For the U-turn you may try:
// U-Turn Right
    if (keyData == (Keys.P))
        if (isUTurnOn)
            if (yt.isYouTurnTriggered){
                yt.ResetYouTurn();
            }else{
                yt.isYouTurnTriggered = true;
                yt.BuildManualYouTurn(true, true);
// U-Turn Left
    if (keyData == (Keys.O))
        if (isUTurnOn)
                yt.ResetYouTurn();
            }else{
                yt.BuildManualYouTurn(false, true);
It works… But it is the manual turn.
What i want to use is the auto uturn Switch left right turn. You know What i mean?
BR
The auto should work with this:
        if (keyData == (Keys.U))
            btnAutoYouTurn.PerformClick();
I think that just the youturn on off?
But you know when uturn i active… You can choose which direction it goes left or right on the top of the screen.
You have to change the Code a little bit for the u turn instead of the lateral
       if (keyData == (Keys.U)) //swap U-turn
                SwapDirection();
                yt.ResetYouTurn();
                return true;
This does work :slight_smile:
