You can’t trust a regular tractor-steering with WAS for position I’d think, but for something like a twintrack where the wheel always returns to dead-ahead… this is what I was working on.
Almost there with the Challenger, but things went a bit.. unusual today.
Settings:
firmware sets absolute position mode, no need to config
at dead-ahead, move the WAS slider anywhere (doesn’t matter) to reset “zero”
CPD - used to define how much turn an “angle” is, recommend perhaps starting at 30
Ackerman - at 100, this takes up the slack on a twin-track (eg, the amount of wheel movement before the tractor actually starts to turn). Recommend 50 to start.
In this case, I think Stanley would help, but who knows if I’ll get back to this machine again
Finally had a chance to do a quick field test on the modified firmware using the Keya as a virtual WAS. Ran around a really bumpy chisel plowed field for about 15 min.
First, it actually worked! I have NOT thoroughly tested and only ran for a short time.
