Hi guys I have a autosteer board connected with RJ45 and I built a machine control
Agomatic but I wanted to connect it with RJ45 instead of usb I have a surface pro so I’m already using a usb to internet adapter so wondering if anyone have any recommendation on what to use ?
Wifi router might be the thing you are looking for.
I’m unfamilar with Agomatic so I have no idea if it supports WiFi…
Assuming all boxes are running Ethernet on the RJ45 physical connections, then a cheap 4 port switch / hub will get everything talking. Cheap WiFi routers from ISP’s usually incorporate a 4 port switch, will often run happily on 12VDC and can be had for free if you hunt around.
