This is the connector for networking / UDP, for Panda_Basis_PCB.
Has anybody found a source for this part, within the EU? Is the part in stock!?
It look like (Electronic components. Distributor, online shop – Transfer Multisort Elektronik) in Poland has them, but None in stock.2022-08-06T22:00:00Z
2.0mm 2.0 Single Double Row Male 240P 140P Breakaway PCB Board Pin Header Long 15 17 19 mm Connector Strip Pinheader 2x40
2mm 2.0mm Pitch 2x3 Pin 6 Pin Female Double Row Straight Pin Header Strip
Can you get these to EU? I’m not 100% sure which length of pins is best.
I don’t know if they ship internationally, but Proto Supplies has the 2x3 header kits and all other headers for the Teensy 4.1. They also sell the Teensy with the headers soldered in. They offer 3 or 4 configurations of header as to whether you want ethernet, USB, or both.
I put 2 small headers on top of each other, you don’t need long pin header then.
