5.8.3 Roll error freeze when unpowered
I’ve found a bug in UDP (which have probably ever been reported since it’s really annoying), with a kaupoi pcb (shouldn’t have importance here).
When you unplug -plug UDP while working, everything is okay.
If you stop powering the arduino, the roll will freeze, and next time you open agopengps, you’ll have to send again x-y axis to unfreeze it.
Is this bug have ever been reported ?
thank for solving this problem.
You probably need this delay.
I don’t know if it is in the latest ino for nano?
Thanks a lot for the help !!
After have checked, I had this problem on 5.7 too
It wasn’t implemented on the latest version of ino.
After adding delay(2000); after setup, it works back as usual.
It’s actually weird because I have this problem on the kaupoi v 4.1 that I use for testing and the one in my tractor, BUT I haven’t got this problem on the “classic PCB V2” that I’m using on an other tractor with Agopengps 5.8.2 (wich also don’t works with kaupoi PCBs).
