Hi I’m looking at putting a steering valve onto a 9370 '99 Case 4 wheel drive tractor, wanted to get the hardware together. I don’t have the tractor here yet. Does any one know if it is a load sense system on this machine?
Not absolutly sure with these older models, think you’ll find tractor has closed centre pump so will have LS but not on steering. Has a priority valve that gives constant flow to the orbital. But best to ask your local steiger mechanic.
If it is anything like the NH versatile’s of the same era it will have a LS on steering. This will be accomplished with a priority valve most likely located under the front right corner of the cab.
