AB creation based on Bing Map
Sometimes it would be great to easily put up an AB line. We all know that satelite images are far from perfect.
However they should be good enough to define directions. If the field is long enough all we care is parallel. We could grab direction from map.
I.e. AB based on A + angle from map.
Would this be feasible?
Sounds complicated compared to the existing option to create an AB-line from the field border.
The field border you can create from the map (GE at least) if you wish.
Hmm that works too, define a boundary from bing, then throw an AB based on that?
