Currently switching from Greenstar to AgOpen. One of the drawbacks is that after setting an AB line I cant change the B point. Sometimes I’ll line up with something and then need to adjust the line.
Just click B again used to work. I don’t believe that has changed.
Yeah but once I save and name the line. After that it’s locked in and no way back.
You can change the direction of the line. So A point is fix and other angle gives other B point
If you record a boundary on the first run then you can use the touch lines to set the ab line
