I succeeded with the 2k/1k resistor combo (some AIO comes with 12k/6k which made the signal weak…)
Also as @Pat suggested I removed the C3 from the pressure input (probably not necessary)
You can add a voltage divider from through hole resistors to the back of the board.
As for the firmware it’s here:
And I’d probably buy the delphi 2 pin connectors (2 grey 1 black) wire everything to the valve and make the terminators as I described it here:
