We have a lot of small fields close to each other. If someone who does not know field names is driving and there is six field is “Drive in list” it takes time to find out the right fields. Is there a way to make it so that “Drive in” would only let you see field you are on? And by way, I mean a way that not a coder can do.
Yeah drive in function use only the start coordinates from each field (the point you were when you created the field the first time).
I don’t even know if they are sorted beginning with the closet one.
It surely would be nice to have it a little more evolved.
Which is why it’s important to create the field where you drive in. So you’re close to the field origin.
I’m not totally sure but I think it was listed alphabetically
id like to be able to adjust the range on it
