Seems, UDP is no prob with it either. ![]()
hi
I bought 2 of these RP2040, and it seems to work ok in AOG ver 5.5 but if I use AOG ver 5.6.2, I lost my steerboks communikation, something is blocking. I am using the special Agio with Rvc
Iāll have to check that and will come back to you
Iāve been trying the dual antenna setup today. I loaded both with the config from the GitHub and everything connects well. The issue I get is that as Iām driving the heading jumps for a split second and comes back. So as Iām driving the tractor on the map will turn on a angle for a split second and then come back on the correct heading. Is there something Iām missing?
Edit: I should add that itās stable when running single antenna and no IMU but when I plug in the second antenna it gets jumpy. Iām running the antennas through a hub and Iāve tried both Fix w/dual as IMU and Dual on version 5.5.0
RTK stable on both Ardusimples?
I can confirm the problem - same here with 5.6.10. Iāll have to reverse-engineer what they have changed⦠![]()
I am wanting to run dual antennas since IMUās are hard to come by. Have you had any luck diagnosing this issue?
I join the consultation, any news about the diagnosis of the problem? I am also very interested in the dual systemā¦
Try using Tonys code for the dual⦠I fought this issue for months with GPS position / heading glitching for brief seconds, Causes no end of trouble but since i started using the other code its been fine⦠Mine always seemed to be worse if you were struggling for RTK signal etc i foundā¦
Where can we find āTonys codeā?
@darrenjlobb This one?
Thats the one, sorry should have linked, try it out and report back, it would be interesting to know if it solved your issue alsoā¦
