How can i delete once selected com s?
Like the COM3
Closed the program, then change the com port number or remove the com Port if it’s a USB adapter and then start the program again.
Or edit the settings config file or clear out your user data folder
It sounds like if you tell AgIO to disconnect, then it’s not supposed to auto connect next time it loads but there might be a bug that still auto connects, might be fixed in the next update.
I manupilated the Agio save to"xyxy" file
IT works with False as Value
