AgoOpenGPS is already running
So today I turn on the computer and the GPS started but the was a porting issue so I restarted and now I get this error whenever I try to enter the app. What is wrong?
The last error messages is as follows:
AutoSteer RecvSystem.InvalidOperationExeption: Invoke cannot be called on a control until the window handle has been created. at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.BeginInvoke(Delegate method, Object[] args) at AgOpenGPS.sp_DatareceivedAutoSteer(Object sender, SerialDataReceivedEventArgs e) in C:\users\Grizs\Desktop\SourceCode\GPS\Forms\SerialComm.Designer.cs:line 200 - 2020-05-19 7:42:28 AM
Maybe it could help to delete the file mentioned here.
Thank you @Larsvest for the hint with the forum and the settingsfile. I have now found the file(s) under C:\Users\AppData\Local\AgOpenGPS. (Windows10)
After removing the files it is up and running again!
Saves me a lot of time. :relaxed:
Which file?
All of them.
They have very long names like this: AgOpenGPS.exe_Url_0rblssmivdoa54owuy23of20z4eingul
The first part (until URL) is always the same.
You could make a backup of them first if you prefer.
I just reinstalled it I needed the newer version anyway
