When you load a saved vehicle with different settings for U-turn, Agopen dont load the settings for U-turn right away, you have to go to U-turn configuration and change a setting before it load the saved settings
Which version are you using?
Something like this was noted in v5.7.2 but should be corrected in v5.7.3.1
I giv it a try ![]()
it is working in 5.7.3.1 not in 5.7.2 so is going to be OK
I was wondering about the same problem!
Where could you find the 5.7.3.1 version?
GitHub - lansalot/FileDump it is here in a zip-file
