AgOpenGPS - Invalid
AgOpen gives an Invalid message in the upper right corner and the rotating no access screen is all I get. AGio loads UDP with no problem. Deleting Appdata hasn’t helped. Any Ideas before I reset all??
edit; It’s 5.7.1
Your gps receiver is not delivering data, or you parked indor?
not inside. I’ll check the GPS. Thanks
Open the UDP monitor and enable GGA output. What do you get?
I get data in the monitor. I am pretty sure that i have a bad connection on the cable. Im gonna make a new one this am.
New cable solved the problem
