| 13:03:01 | From A. B. : if you don’t mind, can I stay with you and listen? |
| 13:03:30 | : Absolutely totally fine |
| 13:07:52 | : UBX parser |
| 13:10:33 | From A. B. : I agree with Doppelgrau. {;lease guys, do not tie the desing only to ubx |
| 13:12:19 | : ESP32 synchronization |
| 13:14:25 | : external libraries unecessary |
| 13:15:22 | : 3 boards sandwiched together and it works |
| 13:15:39 | : V4 pair down options |
| 13:19:01 | : PAOGI description |
| 13:19:56 | : one field missing in the PAOGI |
| 13:20:03 | : ? |
| 13:20:24 | : recommended New spec for PAOGI |
| 13:24:36 | : Arduino set up through UDP |
| 13:24:47 | : V4 |
| 13:26:23 | From A. B. : oh, its now much easier to setup. No need to sit at night any more and write annoing posts to telegram chat |
| 13:37:15 | : EEPROM settings |
| 13:41:40 | : What is the ideal set up, roaming control box or stationary in tractor? |
| 13:41:41 | From A. B. : Its more often possible a situation, where user takes a tablet and goes from tractor to combine. |
| 13:42:31 | From A. B. : so user must be able to IMPORT uino settings. no? |
| 13:43:34 | : File extensions? click on the icon and AOG opens |
| 13:54:14 | : One board shall rule them all. That is V3! |
| 13:55:13 | : Encoder Qs |
| 14:03:02 | : Multiple Boundaries |
Thanks to all of you that took their time today to host and speak at the meeting. It was very interesting and just shows us new guys how much you have put into this. If I can be of any help let me know, I am not a programmer but if there is a place I could be of service.
Thanks again
