AiO faceplate Order
@WildBuckwheat was looking into ordering a set of your faceplates. Just had a couple questions about the ordering process. I am still new to ordering PCB’s. I was following your ordering instructions but once I get down to the options of PCB assembly and stencil I am not to sure what to do. Or do I just add to cart at this point as there is no assembly? Thanks
There is no assembly.
For best appearance I guess you should select black as color. Unless you want something special.
All other parameters should be by default.
Thanks Pat,
Order done
