AIO Standard + ACS712
Hello all,
I’m currently setting up my system ( AIO standard + 4G/Wifi router + cytron) and I was wondering the following : I started AOG some time ago but didn’t completed my previous configuration (PCB V2 Panda), now I’m ready to complete the AIO one. However I would like to power the cytron via a dedicated wire just like the PCB V2 did. But doing so I’m missing the ACS712 that is protecting everything when turning by hand the steering wheel with the motor engaged.
My question is : Is it possible to add an ACS712 and if so, where should I connect the ACS pins on the AIO standard ?
Thanks in advance,
Best regards
You should be able to power only the cytron and use the onboard ACS.
What board exactly you have?
