Hi guys!
Does anyone know where to get info for proper settings for Aio for 2.4 board using serial port?
I tried to use UDP, but it’s somethig wrong either with the PCB or with Teensy. I blame myself that I probably did something wrong during soldering.
When I connect Teensy using serial port, I can conect only to one module. I usualy connect to GPS antena. The Aio lightens antena with a green square. But when I try to connect other modules, I have a message that it isn’t able to connect. However, I have all the data from IMU and WAS in the top left corner when I connect just the GPS antena. But I have another problem - the tractor in the Bottom Right corner is stil PURPLE! I have WAS, IMU, GPS and a work swithch connected and it looks like that no steering module connected. There is nothing happens when i press work switch.
Thank you for your help and sorry for taking your time.
